[Gdal-dev] GDAL and ECWP
Brent Fraser bfraser at geoanalytic.com
Fri Apr 1 16:26:06 EST 2005
Frank,
 Does gdal_translate work with ecwp?  For example, when running:
gdal_translate -of GTiff "ecwp://apps.minerals.nt.gov.au/ntgs
ecwp/NT/TMICol.ecw" test.tif
I get:
Input file size is 10578, 17161
0.ERROR 1: TryWinRasterIO() failed for blocked scanline.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
Are some enhancements needed to make it work?
Thanks!
Brent Fraser
