[Gdal-dev] Kakadu and MrSID conflict
Julien Demaria dem at acri-st.fr
Thu Apr 7 03:28:33 EDT 2005
Ken,
In fact finally I have successfully compiled GDAL with last Kakadu and last
MrSID DSDK ; JP2 with Kakadu and seems work well, MrSID files too, but I
don't know for JP2 MrSID because for JP2 Kakadu is always selected.
I still have the "ld: warning: symbol `kdu_compressed_target virtual table'
has differing s
izes:
         (file ./frmts/o/jp2.o value=0x40; file /project/openev/solaris/Ge
o_DSDK-4.0.10.720/lib/Release/libltidsdk.a(j2k_support.o) value=0x30);
         ./frmts/o/jp2.o definition taken"
but as the Kakadu jp2.o is selected and I use only Kakadu for JP2 I think
there isn't any pb.*
Thanks,
Julien
At 18:36 06/04/2005, Kenneth Melero wrote:
>Julien,
>Unfortunately there is no fix for the moment with configuring both MrSID and
>Kakadu at the same time other than obtaining a MrSID release from Lizrdtech
>that does not contain Kakadu in its internal libraries.
>To turn on MrSID SDK for both .sid and .jp2 files read this previous thread:
>http://xserve.flids.com/pipermail/gdal-dev/2005-March/008304.html
>-Ken
>-----Original Message-----
>From: gdal-dev-bounces at xserve.flids.com
>[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Frank Warmerdam
>Sent: Wednesday, April 06, 2005 9:44 AM
>To: Julien Demaria
>Cc: gdal-dev at xserve.flids.com
>Subject: Re: [Gdal-dev] Kakadu and MrSID conflict
>On Apr 6, 2005 3:32 AM, Julien Demaria <dem at acri-st.fr> wrote:
> > I found that last MrSID DSDK is Kakadu v4.2 based ; so I'll try to
> > downgrade my Kakadu to v4.2...
> > Are there solutions to this conflicts ?
>Julien,
>The only "solution" I am aware of is to drop the Kakadu out of the build,
>and depend on the MrSID driver for JPEG2000 support.  However, I am not sure
>if the GDAL MrSID code is really setup properly to handle JPEG2000.  In
>fact, I haven't personally run into this yet since I don't normally build
>with the MrSID SDK.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
>warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com http://xserve.flids.com/mailman/listinfo/gdal-dev
