[Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Thu Apr 7 15:36:02 EDT 2005
Hey Brent,
Thanks for the update. I've just finished installing the Core SDK. Guess
what. Still no winhttp.h.
I'll take this conversation over to the ERMapper forum since it really isn't
a gdal issue.
Thanks again,
Thom
Thom DeCarlo
   Nothing is sadder than the murder of
a beautiful theory by a gang of ugly facts.
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, April 07, 2005 2:57 PM
> To: Thom DeCarlo; 'gdal-dev'
> Subject: Re: [Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
> Thom,
>   You're likely right, I probably did a few other things (my memory has no
> parity!).
> From reading the Microsoft page, it appears you would be ok  installing
> the
> Windows 2003 Server SDK since is says it supports Windows XP, but I had to
> read it a couple of time to be sure!
> I did a search of my copy of the ECW SDK and I see that I commented out
> the
> following at line 348 of Source\C\NCSUtil\malloc.c:
> #ifndef _WIN32_WCE
> // HMODULE hLib = LoadLibrary(TEXT("kernel32.dll")); //BWF
> // if(hLib) {
> //  FARPROC pProc = GetProcAddress(hLib, TEXT("GlobalMemoryStatusEx"));
> //  if(pProc) {
> //   MEMORYSTATUSEX MemoryStatus;
> //   MemoryStatus.dwLength = sizeof(MEMORYSTATUSEX);
> //   pProc(&MemoryStatus);
> //   nTotalPhysicalMemory = MemoryStatus.ullTotalPhys;
> //  FreeLibrary(hLib);
> #endif // _WIN32_WCE
> Although I'm not sure if that's necessary.  I'll try to do a fresh compile
> with GDAL 1.2.6 (cvs tarball 20050405)
> Brent
> ----- Original Message -----
> From: "Thom DeCarlo" <t.r.decarlo at larc.nasa.gov>
> To: "'gdal-dev'" <gdal-dev at remotesensing.org>
> Sent: Thursday, April 07, 2005 12:21 PM
> Subject: RE: [Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
> > Hi Brent,
> > Well, I'm not sure that's all you did.
> > I'm using:
> > NCSSource_3.1rc1_18Feb05
> > WinXP SP2
> > XP SP2 Full Platform SDK
> > VS.Net 2003 (Version 7.1.3088)
> > .NET Framework 1.1 (Version 1.1.4322 SP1)
> > The only Core SDK that I found seems specific to Windows Server 2003.
> I'm
> > hesitant to install this on my XPSP2 computer. Is there any danger here?
> I
> > haven't installed it and that might be why I still cannot find winhttp.h
> > anywhere on my computer.
> > Frank wrote:
> > > I believe winhttp.h is part of the MS Platform SDK which you need
> > > to download.
> > > I think the build.txt in the ECW SDK directory talks about this a bit.
> > Build.txt does indeed mention the Platform SDK, but only in the section
> > referring to Visual Studio 6. That's why I didn't install it initially.
> > Thanks,
> > Thom
> > Thom DeCarlo
> >               Experience is a wonderful thing
> > It allows you to recognize a mistake when you make it again.
> > > From: Brent Fraser
> > > Sent: Wednesday, April 06, 2005 5:49 PM
> > > Thom,
> > >   I'm successfully using:
> > >     GDAL 1.2.6
> > >     NCSSource_3.1rc1_18Feb05.zip
> > >     VS .Net 2003
> > >     MicroSoft Platform SDK
> > > Download the Core portion of the MicroSoft Platform SDK:
> > >     http://www.microsoft.com/msdownload/platformsdk/sdkupdate/
> > > Edit GDAL's nmake.opt to include the path to the Microsoft SDK:
> > > INC = -I$(GDAL_ROOT)\port -I$(GDAL_ROOT)\ogr -I$(GDAL_ROOT)\gcore \
> > >   -I$(GDAL_ROOT)\alg -IC:\PROGRA~1\MIFD68~1\include
> > > I think that's it...
> > > Brent Fraser
> > Gdal-dev mailing list
> > Gdal-dev at xserve.flids.com
> > http://xserve.flids.com/mailman/listinfo/gdal-dev
