[Gdal-dev] double free or corruption in vrt with gcp's
vincent at ecovla.nl vincent at ecovla.nl
Mon Apr 11 06:57:21 EDT 2005
Folks,
[sorry when posting twice, tried through gmane but doesn't seem to come
trough...]
I have some problems using warped vrt files with gcp's, and I'd
appreciate it if someone could shed some light on it. The situations is
as follows:
o ASTER L2 imagery (hdf) is converted to a warped vrt file using
"gdalwarp -of vrt -srcnodata 0 -dstnodata 0 -s_srs "EPSG:4326" -t_srs
"EPSG:4326" -rcs
HDF4_EOS:EOS_SWATH:"${hdfvnir}":SurfaceReflectanceVNIR:Band${band}
tmp.vnir.${band}.vrt
(don't focus on the file names, it's batch processing). This works ok.
The resulting vrt file is attached and looks good.
o Then whatever I try to do on this file fails with a segfault or the
following error: *** glibc detected *** double free or corruption (out):
0x00000000005a7d90 ***
Aborted (core dumped)
For simplicity's sake I'll show the output of "gdalinfo tmp.vnir.1.vrt"
 (actually I want to do gdal_translate, but the error also appears with
gdalinfo):
Driver: VRT/Virtual Raster
Size is 5507, 4882
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
Origin = (112.808259,0.315868)
Pixel Size = (0.00013521,-0.00013521)
Corner Coordinates:
Upper Left  ( 112.8082592,   0.3158685) (112d48'29.73"E,  0d18'57.13"N)
Lower Left  ( 112.8082592,  -0.3442274) (112d48'29.73"E,  0d20'39.22"S)
Upper Right ( 113.5528614,   0.3158685) (113d33'10.30"E,  0d18'57.13"N)
Lower Right ( 113.5528614,  -0.3442274) (113d33'10.30"E,  0d20'39.22"S)
Center      ( 113.1805603,  -0.0141794) (113d10'50.02"E,  0d 0'51.05"S)
Band 1 Block=512x128 Type=Int16, ColorInterp=Undefined
  NoData Value=0
And here is the backtrace of "gdb gdalinfo core":
#0  0x0000002a9816be69 in kill () from /lib/libc.so.6
#1  0x0000002a95fe9891 in pthread_kill () from /lib/libpthread.so.0
#2  0x0000002a95fe9c12 in raise () from /lib/libpthread.so.0
#3  0x0000002a9816bb62 in raise () from /lib/libc.so.6
#4  0x0000002a9816cef2 in abort () from /lib/libc.so.6
#5  0x0000002a981a3e14 in malloc_usable_size () from /lib/libc.so.6
#6  0x0000002a981a48da in free () from /lib/libc.so.6
#7  0x0000002a958bc150 in VSIFree () from /usr/local/lib/libgdal.so.1
#8  0x0000002a958ca42d in GDALDestroyWarpOptions () from
#9  0x0000002a958d3b4e in GDALWarpOperation::WipeOptions() () from
#10 0x0000002a958d3ab9 in GDALWarpOperation::~GDALWarpOperation() ()
#11 0x0000002a9589d6f4 in VRTWarpedDataset::~VRTWarpedDataset() () from
#12 0x0000002a958a9df9 in GDALClose () from /usr/local/lib/libgdal.so.1
#13 0x0000000000402e59 in main ()
Alas I'm on amd64 and valgrind has not yet been ported to that arch.
I'm using a fresh gdal from cvs, and gentoo linux on amd64. In this
case, GDAL has been compiled without any optimization.
Any thoughts?
Cheers,
Vincent.
