[Gdal-dev] Re: Tiff problems
Frank Warmerdam fwarmerdam at gmail.com
Fri Apr 22 13:17:45 EDT 2005
On 4/22/05, Peng Gao <pgao at esri.com> wrote:
> Frank,
> GDAL list and site seem to be down.
Peng,
I am able to get through to www.gdal.org, and www.remotesensing.org/gdal
currently.  There have been some problems reported with www.remotesensing.org
earlier in the day.  I have logged in and restarted the mail queue to be
sure, but I didn't see anything obviously wrong.  I should soon see if this
email goes through.
> ---------- Forwarded message ----------
> From: Peng Gao <pgao at esri.com>
> To: GDAL-dev list <gdal-dev at remotesensing.org>
> Date: Fri, 22 Apr 2005 08:24:01 -0700
> Subject: Tiff problems
> I have a 4-bit tiff with colormap. GDAL returns pixel depth Byte, and the
> pixels are all wrong.
> I have another single band 8-bit tiff with colormap. GDAL recognizes as
> an 8-bit 4 band image.
> I have the test images available.
I think I will need the test files.  There are a variety of circumstances in
which GDAL uses the libtiff internal conversion to RGBA.  This might be
happening in the case of the file that gets converted to four bands.
Best regards,
