[Gdal-dev] GDAL CVS access
Frank Warmerdam fwarmerdam at gmail.com
Mon Apr 25 10:16:57 EDT 2005
On 4/25/05, Peng Gao <pgao at esri.com> wrote:
> I can't login:
> cvs login
> (Logging in to cvsanon at cvs.maptools.org)
> cvs login: authorization failed: server cvs.maptools.org rejected access to
> /cvs/maptools/cvsroot for user cvsanon
> *****CVS exited normally with code 1*****
> I am using WinCvs. I tried password 'enter' and '*enter*' and both
> didn't work. What did I miss?
Peng,
The password is blank I believe.  Where it says enter, it means for you
to just hit the enter button on the keyword.   If it still doesn't work let
me know and I will dig into it further.
Best regards,
