[Gdal-dev] gdalwarp documentation/tutorial
Paul Surgeon surgpub at telkomsa.net
Mon Apr 25 16:16:18 EDT 2005
On Sunday, 24 April 2005 16:07, Frank Warmerdam wrote:
> Coming back to the original problem, what build of GDAL are
> you using?  You might want to try FWTools and verify it works
> with that (http://fwtools.maptools.org).
Thanks Frank, I installed FWTools and suddenly everything works.
I thought all along that the error messages were a result of bad command line
parameters.  :)
Paul
