[Gdal-dev] problem with te using gdalwarp
Sam Gurt skyman302 at gmail.com
Wed Apr 27 17:39:57 EDT 2005
Heres the command I'm using:
gdalwarp -s_srs EPSG:4269 -t_srs "+proj=stere +lat_0=46.1978
+lon_0=-122.1911 +datum=WGS84" -tps -rcs -te -122.2411 46.1478
-122.1411 46.2478 C:\71569060\71569060.tif C:\stereo.tif
However, this is the output:
Creating output file that is 0P x 0L.
ERROR 1: _TIFFVSetField:C:\stereo.tif: Bad value 0 for "RowsPerStrip"
Is this a bug in GDAL or did I do something wrong. I'm using gdal from
fwtools 0.9.6 under windows. However I've also tried this using gdal
by itself from the gdal website under linux and I get the same error.
