[Gdal-dev] ogr2ogr and field matching
Armin Burger armin.burger at gmx.net
Tue Aug 2 15:04:59 EDT 2005
Hello everybody,
I tried to use ogr2ogr for loading data from shapefiles into PostGIS
because it gives more flexibility than the shp2pgsql utilitiy.  I tried
to combine data from different sources that can have differences in the
field names of the shapefiles. ogr2ogr offers the possibility to specify
the SQL command for loading. So I tried
"ogr2ogr -sql "SELECT ARRGCDL0 AS iso
FROM countries WHERE ARCNTY_ID>100"  -a_srs "EPSG:4326" -append
 -f PostgreSQL PG:'host=localhost user=postgres dbname=testdb'
countries.shp"
But I get the error
ERROR 1: SQL: Missing comma after column ARRGCDL0 in SELECT statement.
So there seems to be no possibility to map an existing column in the
shapefile to an existing in the PG table using the 'AS' statement. When
the two column names differ, the data from the shapefile field are just
not loaded into the PG table. Are there any workarounds for that?
Thanks in advance for any help
Armin
