[Gdal-dev] gdal with ecwsdk 3.2
Ken Sewell sewell at dramail.com
Thu Aug 4 17:25:57 EDT 2005
Answering my own question.  It seems a simple replace of libNCSE* with
libecwj2.so is all thats needed in the configure script.   Also in the ecw
directory you need to do 'ln -s Source/include .'
This gets it so that GDAL mostly compiles.  But here's the problem now.
In the frmts/ecw directory the compiler has problems.  Mostly it seems to
do with typedefs.  It looks like the gdal code needs to #include "ECW.h".
This help resolve alot of the problems, however there are still some I
haven't tracked down.  Am I the only one having issues with this?  Has
anyone else tried these libraries?  I'm building on Suse 9.3 64-bit.
Thanks for any help.
Ken Sewell                   Defense Research Associates
Project Engineer             3915 Germany Lane, Suite 102
937-656-4899 x3004           Beavercreek, Ohio 45431-1608
On Thu, 4 Aug 2005, Ken Sewell wrote:
> I've got the ECW SDK 3.2 (11 Jun 2005 ) built.  I tried to configure gdal
> (cvs checked out 03 Aug 2005 ) with it, but the configure script is
> looking for the libNCSE*.so files and the ecw 3.2 builds one library named
> libecwj2.so.  Is there a patch or trick to get it to work that I'm
> missing?
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
