[Gdal-dev] gdal with ecwsdk 3.2
Ken Sewell sewell at dramail.com
Fri Aug 5 09:39:53 EDT 2005
I'll give those command line options a try.  Is the source for any of the
3.1 versions available?  From ERMapper's site I can only find 3.2.  I was
using the prebuilt binary libs from the gdal ftp site, but they don't seem
to work on the 64-bit machine.  This is what lead me into the 3.2 problems
in the first place.  I really don't care which I use, I was just hoping to
get it working by today, so I could let it run some jobs over the weekend.
Ken Sewell                   Defense Research Associates
Project Engineer             3915 Germany Lane, Suite 102
937-656-4899 x3004           Beavercreek, Ohio 45431-1608
On Thu, 4 Aug 2005, Bill Binko wrote:
> Ken,
> Frank is on top of this, and we're hoping for a new build of ECW 3.2 that
> solves most of these issues.
> I'm sure he can get you a config that works.
> You might(!) get away with adding -DLINUX -DPOSIX and -DUNICODE to the
> build command line -- it has worked before.
> Other than that, I'll wait for Frank's response.
> Bill
> On Thu, 4 Aug 2005, Ken Sewell wrote:
> > Answering my own question.  It seems a simple replace of libNCSE* with
> > libecwj2.so is all thats needed in the configure script.   Also in the ecw
> > directory you need to do 'ln -s Source/include .'
> > This gets it so that GDAL mostly compiles.  But here's the problem now.
> > In the frmts/ecw directory the compiler has problems.  Mostly it seems to
> > do with typedefs.  It looks like the gdal code needs to #include "ECW.h".
> > This help resolve alot of the problems, however there are still some I
> > haven't tracked down.  Am I the only one having issues with this?  Has
> > anyone else tried these libraries?  I'm building on Suse 9.3 64-bit.
> > Thanks for any help.
> > > I've got the ECW SDK 3.2 (11 Jun 2005 ) built.  I tried to configure gdal
> > > (cvs checked out 03 Aug 2005 ) with it, but the configure script is
> > > looking for the libNCSE*.so files and the ecw 3.2 builds one library named
> > > libecwj2.so.  Is there a patch or trick to get it to work that I'm
> > > missing?
> > > _______________________________________________
> > > Gdal-dev mailing list
> > > Gdal-dev at lists.maptools.org
> > > http://lists.maptools.org/mailman/listinfo/gdal-dev
