[Gdal-dev] Shape Polygon to Line
Frank Warmerdam fwarmerdam at gmail.com
Wed Aug 17 10:01:29 EDT 2005
On 8/17/05, Julien Demaria <dem at acri-st.fr> wrote:
> Hi,
> I try to translate a polygon shapefile to a line shapefile with ogr2ogr ;
> I've tried
> ogr2ogr -nlt LINESTRING -lco SHPT=ARC Austrialine.shp Austria.shp
> but it returns this error :
> ERROR 1: Attempt to write non-linestring (POLYGON) geometry to ARC type
> shapefile.
> ERROR 1: Terminating translation prematurely after failed translation of
> layer Austria
> Is it possible to translate polygon to line using ogr2ogr ?
Julien,
Sorry, not I don't think it is.  You could write a python script to
accomplish this transformation, but it would be a non-trivial
effort.
Best regards,
