[Gdal-dev] GDAL 1.3.0, compile errors
Frank Warmerdam fwarmerdam at gmail.com
Fri Aug 19 20:55:30 EDT 2005
On 8/19/05, Armin Burger <armin.burger at gmx.net> wrote:
> Hello,
> I tried to compile GDAL 1.3.0 on Debian Linux using the configuration
> ./configure --with-pg=/usr/local/pgsql/bin/pg_config
> --with-geos=yes      --with-xerces --with-xerces-lib="-L/usr/local/lib
> -lxerces-c1_7_0 -lpthread"  --with-xerces-inc=/usr/local/include/xercesc
> --with-ecw=/home/install/mapserver/ecwsdk-3.1.25Jan05-linux/ --with-mysql=no
Armin,
It seems that the Interlis driver requires a newer version of Xerces than 1.7.0.
I would suggest your upgrading to at least Xerces 2.x.  Let me know if
that solves the problem.  I think I may need to advertise GDAL as depending
on Xerces 2.0 or newer from now on.
Best regards,
