[Gdal-dev] problems building gdal with xerces and ecw
Raphaëla Saling raphaela_saling at caramail.com
Mon Aug 22 13:20:49 EDT 2005
Thank you very much, now all is Ok .
I try with gdal-1.3.0
Best regards,
Raphaëla
> De: Frank Warmerdam <fwarmerdam at gmail.com>
> A: Raphaëla Saling <raphaela_saling at caramail.com>
> Objet: Re: [Gdal-dev] problems building gdal with xerces and ecw
> Date: Mon, 22 Aug 2005 11:11:21 -0400
> On 8/22/05, Raphaëla Saling <raphaela_saling at caramail.com> wrote:
> >  /usr/bin/ld: warning: libstdc++.so.5, needed by /usr/src/pourmapserver/ecwsdk-3.1.25Jan05-linux/lib/libNCSEcw.so, may conflict with libstdc++.so.6
> Raphaëla,
> I can see a couple solutions to this.
>  - GDAL 1.3.0's configure logic for Xerces now ignores warnings so it shouldn't
>    be so sensitive to this problem.
>  - Build the ECW SDK yourself from source, so that it will be linked with the
>    same libstdc++ that you are using for everything else.   This can be tricky
>    of course.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | <a href=http://pobox.com/~warmerdam>http://pobox.com/~warmerdam</a>and watch the world go round - Rush    | Geospatial Programmer for Rent
Protek-on: CaraMail met en oeuvre un nouveau Concept de Sécurité Globale - www.caramail.com
