[Gdal-dev] Importing VMAP0 into PostGIS database;
Frank Warmerdam fwarmerdam at gmail.com
Mon Aug 22 16:38:49 EDT 2005
On 8/22/05, Martin Spott <Martin.Spott at mgras.net> wrote:
> Martin Spott wrote:
> > BTW, I just found out that in order to compile ogdi-3.1.5 on 64 bit
> > Solaris you have to alter 'ogdi/c-api/ecs_xdr.c' and turn any
> > occurrence of IXDR_*_LONG intp IXDR_*_INT32, see:
> > I'll report later if this actually results in a working driver  :-)
> No, it does not. Neither does the driver crash nor does it recognise
> the VMAP0 data as valid - which it definitely does on 32 bit Sparc.
Martin,
Thanks for the note.  The conclusion seems to be that the OGDI VRF
driver (and possible the OGDI RPC protocol?) is not currently 64bit safe.
I am not expecting to look into this in the near future but it is good to know.
(I have replied partly as an excuse to cc: ogdidev about the issue).
Best regards,
