[Gdal-dev] adding gcp's
Frank Warmerdam fwarmerdam at gmail.com
Tue Aug 23 11:50:47 EDT 2005
On 8/23/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> Hi list,
> I am trying to create a geotiff and add ground control points to it, using the following command:
> gdal_translate ondergrond.tif ondergrond_new.tif -gcp 0 0 63978 458335 -gcp 1290 1619 85630 438699
> When I do gdalinfo, the gcp's are added, but the corner info is not using it:
Bart,
A review of the gdalinfo code shows that it does not try and
use GCPs for computing georefencing.  It will only use a
geotransform (if available).
Sorry...
Best regards,
