[Gdal-dev] Installing header files?
Frank Warmerdam fwarmerdam at gmail.com
Tue Aug 23 14:17:32 EDT 2005
On 8/23/05, Jonathan Greenberg <jgreenberg at arc.nasa.gov> wrote:
> Is there a trick to getting GDAL 1.3.0 to install all the header files in
> the appropriate locations?  I can probably hand-copy them, but I'm trying to
> compile GRASS 6.1, for instance, and it needs the jpeglib.h include.  I did
> a file search and found it IN the gdal-1.3.0 source distribution but it does
> not appear to get installed when I do a configure-> make-> make install.
Jonathan,
GDAL only installs it's own *public* include files.  The jpeg
include files are not related to the public interface of GDAL
and so are not installed.  I would suggest you download and
install libjpeg separately.   You can find info on it at:
  http://www.ijg.org/
Best regards,
