[Gdal-dev] missing function to destroy properly OGRStyleTool ?
Thu Dec 1 14:44:09 EST 2005
On 11/28/05, Fabien Dachicourt <support at geoimage.fr> wrote:
> I know that many problems appear when the "new" is done inside gdal/ogr
> library, whereas the "delete" is done outside (the best example is
> OGRGeometry for which we have to use OGRGeometryFactory to create and
> destroy geometries).
> My question is : how can i delete properly these OGRStyleTools ?
Fabien,
Good question.  The answer is that doing the delete
yourself is ok if you are using the same heap as the GDAL DLL.
This is always the case on Unix/Linux.
If not, they need to be deleted in the GDAL DLL,
but no appropriate destroy method has been provided.
I would appreciate your filing a bug report on this issue.
Best regards,
