[Gdal-dev] Planar Configuration Type 2
Julien Demaria dem at acri-st.fr
Fri Dec 2 03:26:18 EST 2005
Reinaldo,
You have to use the -co "INTERLEAVE=PIXEL" option of the GTiff gdiver.
GDAL uses "INTERLEAVE=BAND" by default.
See here: http://www.gdal.org/frmt_gtiff.html
Best Regards,
Julien
Reinaldo Escada Chohfi a écrit :
> Hello everyone,
> Is there any way to make gdal_translate not set planar configuration
> type 2 on a rgb geotif image.  I am running a program that does not like
> this type of input.
> Thanks in advance.
> Reinaldo
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
