[Gdal-dev] GDAL_MERGE Memory Error
Reinaldo Escada Chohfi rec at geodesign.com.br
Fri Dec 2 15:38:31 EST 2005
Hello everyone,
I'm running gdal_merge.py and get the following memory allocation error
when using the -n 0 flag:
   File "gdal_merge.py", line 478, in ?
     fi.copy_into( t_fh, band, band, nodata )
   File "gdal_merge.py", line 288, in copy_into
     nodata_arg )
   File "gdal_merge.py", line 110, in raster_copy
     nodata )
   File "gdal_merge.py", line 147, in raster_copy_with_nodata
     nodata_test = Numeric.equal(data_src,nodata)
MemoryError: can't allocate memory for array
I run the program twice using the same input datasets when making a mosaic
to extract two images with the -n 0 flag.  I get one image out. However, I
get the above error when trying to get the second image out.  I get the
same error when trying to do the same operation on other inputs.  The
output images are all the same size about 500 MB.
I'm running gdal_merge.py on a AMD 64-bit machine with 4 GB of RAM and lots
of disk space.
Please let me know how to fix this problem.
Thanks in advance.
Reinaldo
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051202/e0f759ff/attachment.html
