[Gdal-dev] Free OGRGeometry?
Sun Dec 4 10:06:05 EST 2005
On 12/4/05, Ben Discoe <ben at vterrain.org> wrote:
> Craig,
> Ogrinfo works great in both Debug and Release.  I don't use nmake.opt; like
> many people, i consider command-line development to be a primitive relic of
> the 1970s.  As soon each GDAL version is released, you'll find that i post
> the MSVC solution/projects for GDAL/OGR to this mailing list.  Those are
> harmoniously synchronized by Configuration.
> Reminder: http://vterrain.org/dist/gdal131_vc71.zip
> You could try to hack the "nmake" stuff to support both Debug and Release,
> but it would be terribly complex and error-prone.  I did this myself for the
> first couple years, it was always a struggle.
> Each release, i have encouraged adoption of the MSVC files as an alternative
> to the "nmake" stuff, but to date i don't see any mention of them on
> http://www.gdal.org/download.html or http://www.gdal.org/gdal_building.html
Ben,
If you would be willing to make up an explanation web page
at a constant address with links to the solution zip files for
each version, I would be thrilled to put a link on the download,
and build pages for GDAL.
But from my end, it is error prone to need to update things
for each release.
Best regards,
