[Gdal-dev] Setting Min/Max/Null raster values on output
Garrett Potts potts at cfl.rr.com
Mon Dec 5 09:41:28 EST 2005
Hello All:
I see on the writing side I can specify no data values (or NULL)  for
each band but is there a way to specify the min max value for each
band as well?  I use the GetRasterMinimum and Maximum when reading
but I don't see a corresponding Set function.
Take care all and thank you for any insight
Garrett
