[Gdal-dev] Problem using gdal_translate
Jimmy Wang nekewong at yahoo.com
Tue Dec 6 04:26:47 EST 2005
  Hi all,
  I use global mapper to generate a 24bit RGB .tif file from a USGS DEM demdata.dem, but I found that the .tif file has a odd coordinate.
  gdalinfo  demdata.dem:
  Driver: USGSDEM/USGS Optional ASCII DEM (and CDED)
Size is 1201, 1201
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AXIS["Lat",NORTH],
    AXIS["Long",EAST],
    AUTHORITY["EPSG","4326"]]
Origin = (110.999583,31.000417)
Pixel Size = (0.00083333,-0.00083333)
Metadata:
  AREA_OR_POINT=Point
Corner Coordinates:
Upper Left  ( 110.9995833,  31.0004167) (110d59'58.50"E, 31d 0'1.50"N)
Lower Left  ( 110.9995833,  29.9995833) (110d59'58.50"E, 29d59'58.50"N)
Upper Right ( 112.0004167,  31.0004167) (112d 0'1.50"E, 31d 0'1.50"N)
Lower Right ( 112.0004167,  29.9995833) (112d 0'1.50"E, 29d59'58.50"N)
Center      ( 111.5000000,  30.5000000) (111d30'0.00"E, 30d30'0.00"N)
Band 1 Block=1201x1201 Type=Int16, ColorInterp=Undefined
  NoData Value=-32767
  Unit Type: m
gdalinfo tiffile.tif:
Driver: GTiff/GeoTIFF
Size is 1201, 1201
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235630016,
    PRIMEM["Greenwich",0],
    UNIT["arc-second",4.848136811095357e-006],
Origin = (399598.500000,111601.500000)
Pixel Size = (3.00000000,-3.00000000)
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Upper Left  (  399598.500,  111601.500) (399598d30'0.00"E,111601d30'0.00"N)
Lower Left  (  399598.500,  107998.500) (399598d30'0.00"E,107998d30'0.00"N)
Upper Right (  403201.500,  111601.500) (403201d30'0.00"E,111601d30'0.00"N)
Lower Right (  403201.500,  107998.500) (403201d30'0.00"E,107998d30'0.00"N)
Center      (  401400.000,  109800.000) (401400d 0'0.00"E,109800d 0'0.00"N)
Band 1 Block=1201x1 Type=Byte, ColorInterp=Red
Band 2 Block=1201x1 Type=Byte, ColorInterp=Green
Band 3 Block=1201x1 Type=Byte, ColorInterp=Blue
  My question is that how can I use gdal_translate to generate a 24bit RGB .tif file from the DEM in the same area.
  Thanks for your help!
  Jimmy
 Yahoo! Personals
 Let fate take it's course directly to your email.
 See who's waiting for you Yahoo! Personals
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051206/8cef1be0/attachment.html
