[Gdal-dev] Compling GDAL 1.3.1 in MinGW
Daniel Wallner daniel.wallner at bredband.net
Thu Dec 8 19:29:34 EST 2005
I just stumbled into this myself a few hours ago :)
The problem is in this file:
frmts/gtiff/libtiff/tif_jpeg.c
Comment out line 69 and 71
(Don't know a clean solution though.)
And unfortunately here too:
(eeek, my bad, I wrote that driver :)
frmts/rik/GNUmakefile
you need to add -I../zlib to the compile options
(Don't know how this is best done either.)
Then you need to add cpl_vsil_win32.o to
port/GNUmakefile too.
That should do it.
And I think you need these options:
./configure --without-unix-stdio-64 --with-sqlite=/c/mingw
Regards,
Daniel
> From: Mike Leahy <mgleahy at golden.net>
> Date: 2005/12/09 fr AM 12:07:32 CET
> To: gdal-dev at lists.maptools.org
> Ämne: [Gdal-dev] Compling GDAL 1.3.1 in MinGW
> Hello list,
> I'm hoping some of the other users out there that have has success with
> this might be able to give me some advice.  I've been trying to compile
> GDAL with MinGW/MSYS, and I'm currently running into trouble when the
> make process hits tif_jpeg.c.  I've configured GDAL with the following
> options:
> ./configure --prefix=/usr/local --with-jpeg=internal --with-png=internal
> --with-tiff=internal --with-libz=internal --with-sqlite=/c/mingw
> And I get the following errors when I compile:
> In file included from ../../jpeg/libjpeg/jpeglib.h:24,
>                  from tif_jpeg.c:75:
> ../../jpeg/libjpeg/jconfig.h:12:1: warning: "HAVE_STDLIB_H" redefined
> In file included from tif_config.h:2,
>                  from tiffconf.h:3,
>                  from tiff.h:30,
>                  from tiffio.h:33,
>                  from tiffiop.h:60,
>                  from tif_jpeg.c:27:
> ../../../port/cpl_config.h:75:1: warning: this is the location of the
> previous definition
> In file included from tif_jpeg.c:75:
> ../../jpeg/libjpeg/jpeglib.h:94: error: syntax error before "boolean"
> ../../jpeg/libjpeg/jpeglib.h:94: warning: no semicolon at end of struct
> or union
> ../../jpeg/libjpeg/jpeglib.h:95: warning: type defaults to `int' in
> declaration of `JQUANT_TBL'
> ../../jpeg/libjpeg/jpeglib.h:95: warning: data definition has no type or
> storage class
> ../../jpeg/libjpeg/jpeglib.h:110: error: syntax error before "boolean"
> ../../jpeg/libjpeg/jpeglib.h:110: warning: no semicolon at end of struct
> or union
> ../../jpeg/libjpeg/jpeglib.h:111: warning: type defaults to `int' in
> declaration of `JHUFF_TBL'
> ../../jpeg/libjpeg/jpeglib.h:111: warning: data definition has no type
> or storage class
> ../../jpeg/libjpeg/jpeglib.h:160: error: syntax error before "boolean"
> ../../jpeg/libjpeg/jpeglib.h:160: warning: no semicolon at end of struct
> or union
> ../../jpeg/libjpeg/jpeglib.h:175: error: syntax error before '*' token
> ../../jpeg/libjpeg/jpeglib.h:175: warning: type defaults to `int' in
> declaration of `quant_table'
> ../../jpeg/libjpeg/jpeglib.h:175: warning: data definition has no type
> or storage class
> ../../jpeg/libjpeg/jpeglib.h:179: error: syntax error before '}' token
> ../../jpeg/libjpeg/jpeglib.h:179: warning: type defaults to `int' in
> declaration of `jpeg_component_info'
> ../../jpeg/libjpeg/jpeglib.h:179: warning: data definition has no type
> or storage class
> ../../jpeg/libjpeg/jpeglib.h:254: error: syntax error before "boolean"
> ../../jpeg/libjpeg/jpeglib.h:254: warning: no semicolon at end of struct
> or union
> ../../jpeg/libjpeg/jpeglib.h:259: error: syntax error before '}' token
> ../../jpeg/libjpeg/jpeglib.h:269: error: syntax error before "boolean"
> ../../jpeg/libjpeg/jpeglib.h:269: warning: no semicolon at end of struct
> or union
> etc...
> I've been digging around, and found some stuff about different ways of
> declaring booleans when compiling GDAL with MinGW (e.g., int vs.
> unsigned char), but from what I can tell after looking at the code this
> seems to have been taken care of already (at least in GDAL-1.3.1).  Is
> there be anything else I should try?
> Regards,
> Mike
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
