[Gdal-dev] Problems installing gdal-grass-1.3.1
Maik Trömel maik.troemel at maitro.net
Fri Dec 9 05:44:29 EST 2005
Hello ,
I've got a problem installing gdal-grass-1.3.1 from binarys. Up till now
nobody was able to help me.
I have installed:
proj-4.4.9
geos-2.1.4
gdal-1.3.1
grass: 6.0.1
and now i want to install gdal-grass-1.3.1. But when I run "./configure
--with-grass='/.../grass-6.0.1/lib/' " I get as result:
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld:
 conftest2.o: relocation R_X86_64_32 can not be used when making a
shared object
; recompile with -fPIC
conftest2.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
checking for g++ -shared ... no(1)
checking for ld -shared ... no
checking for gdal-config... /usr/local/bin/gdal-config
using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.0.1/lib/ requested,
but librar
ies not found!
What's going wrong?
Thanks a lot for your help!
Greetings Maik
