[Gdal-dev] gdal_merge: output colors reverted
Fri Dec 9 14:05:56 EST 2005
On 12/9/05, Maciek Sieczka <werchowyna at epf.pl> wrote:
> Frank,
> I have 2 tif+tfw B/W (black on white) sheets of topo map. Both are
> something like this (they only differ very slighlty in pixel size and
> size):
Maciek,
Could you try adding the -pct switch when you run
gdal_merge.py?   This should copy the colortable
from the first image to the result image.
Best regards,
