[Gdal-dev] Compling GDAL 1.3.1 in MinGW
Pete Nagy Peter.Nagy at vexcel.com
Fri Dec 9 17:23:11 EST 2005
What I should have said is that I did a MinGW build using cygwin bash
shells, instead of the MSYS shell, by following the recommendations to
simply put the mingw compiler first in the path.
-> Pete
> On 12/9/05, Mike Leahy <mgleahy at golden.net> wrote:
> > Frank,
> > Thanks - that did the trick.
> > This leads me to a more general question: would I be better off if I
> > were to use Cygwin instead of MinGW/MSYS for compiling code on Win32?
> > It's been a while for me, but I seem to recall that Cygwin uses bash...
> Mike,
> The cygwin build case has some quirks as well, but at least
> it should work out of the box for simple configurations.  One
> of the messy things (I think) about the cygwin builds is that
> it is very hard to add close source external libraries.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
