[Gdal-dev] OGRLayerAttrIndex
Chapman, Martin MChapman at sanz.com
Sat Dec 10 13:21:54 EST 2005
Frank,
I have a class that allows me to insert new geometries into a shape
file.  I'm also using a spatial index on each file.  I noticed the
method GetIndex() on the OGRLayer and the fact that the class
OGRLayerAttrIndex has methods like AddToIndex() and RemoveFromIndex().
What I would like to do is incrementally add or delete one geometry to
the index at a time as I add/remove geometries, rather than dropping the
whole index and rebuilding it when I modify the file.  I tried to use
the AddToIndex() function but it didn't add anything to the index file.
Could you explain to me how to use the OGRLayerAttrIndex class?
Thanks in advance,
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051210/617a6dd1/attachment.html
