[Gdal-dev] Problems installing gdal-grass-1.3.1
Hernán De Angelis hernan.deangelis at glocalnet.net
Sat Dec 10 18:03:50 EST 2005
You have to give the basic path:
--with-grass=/usr/local/grass-6.0.1/
hope this helps
El Viernes 09 Diciembre 2005 11.44, Maik Trömel escribió:
> Hello ,
> I've got a problem installing gdal-grass-1.3.1 from binarys. Up till now
> nobody was able to help me.
> I have installed:
> proj-4.4.9
> geos-2.1.4
> gdal-1.3.1
> grass: 6.0.1
> and now i want to install gdal-grass-1.3.1. But when I run "./configure
> --with-grass='/.../grass-6.0.1/lib/' " I get as result:
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bi
>n/ld: conftest2.o: relocation R_X86_64_32 can not be used when making a
> shared object
> ; recompile with -fPIC
> conftest2.o: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> checking for g++ -shared ... no(1)
> checking for ld -shared ... no
> checking for gdal-config... /usr/local/bin/gdal-config
> using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
> checking for G_asprintf in -lgrass_gis... no
> configure: error: --with-grass=/usr/local/grass-6.0.1/lib/ requested,
> but librar
> ies not found!
> What's going wrong?
> Thanks a lot for your help!
> Greetings Maik
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Hernán De Angelis
