[Gdal-dev] "Old-Style" ESRI .PRJ files -- Access Violation on ImportFromESRI
Sat Dec 10 23:34:28 EST 2005
On 12/10/05, Christopher Michaelis <cmichaelis at happysquirrel.com> wrote:
> Ben,
> Thanks very much for the "CSLLoad" trick! That seemed to make all the
> difference in the world. Using your code excerpt makes it work
> beautifully... apparently my fread approach was flawed. Problem solved!
Chris,
The problem is that importFromESRI() expects a "string
list" which should be an array of "char *" with a NULL as the
last entry in the array.  Because you just passed in &pszWKT
there was no proper NULL terminator for the list.
I presume that was the cause of the crash.
Best regards,
