[Gdal-dev] Re: UTF-8 problem with ogr2ogr
Etienne Dube etdube at globetrotter.net
Sun Dec 11 12:55:35 EST 2005
This is correct. I've managed to insert latin1 characters in a
UTF8-encoded DB with ogr2ogr, by setting the PGCLIENTENCODING
environment variable to LATIN1 (prior to running ogr). In Windows, that
would be:
SET PGCLIENTENCODING=LATIN1
Good luck,
Etienne
Charlie Savage wrote:
> What most likely is happening:
> * Your postgresql database is in UTF8
> * You are loading data from some other encoding, lets say Latin1,
> where the character is greater than 155.  For example, something like
> a tilde (~)
> * OGR loads up the postgresql client libraries it is linked against
> * The library code assumes utf8 and is not told otherwise by ogr2ogr
> * The ~ character is not valid in utf8 because in utf8 it occupies
> more than one btye
> * You get an error message.
> Unfortunately, ogr2ogr does not support encodings at all and thus
> there isn't much you can do.  I think you may be able to influence the
> encoding the postgresql client library assumes by fiddling with
> environmental variables or the locale settings on Linux.  You'll have
> to check the postgresql documenation to see.   Alternatively,
> recompile ogr2ogr and add in a call to the postgresql client library
> telling it the encoding of the source dataset.
> For ogr2ogr support for encodings you'll have to lobby Frank.
> Charlie
> Sorokine, Alexandre wrote:
>> Hello!
>> I was trying to convert an ESRI .mdb into PostgreSQL/PostGIS with
>> ogr2ogr (from FWTools 1.0.0a7 on Windows).  However, I've got the
>> following error:
>> ERROR: Invalid UTF-8 byte sequence detected near byte 0xb0
>> As far as I understand this problem is related to character
>> encoding.  I wonder if anybody knows what can be done about that?
>> Alex Sorokine, Ph.D. <sorokina at ornl.gov <mailto:sorokina at ornl.gov>>
>> Oak Ridge National Laboratory
>> tel. (865) 576-7597 fax. (865) 241-6261
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
