[Gdal-dev] ERDAS IMG .aux file
Tue Dec 13 17:20:12 EST 2005
On 12/13/05, Reinaldo Escada Chohfi <rec at geodesign.com.br> wrote:
> Hi,
> Does anyone know where one could get information on the ERDAS .aux file format?
Reinaldo,
Erdas .aux files are in Hierarchical File Architecture format,
the same as .img files.  You can read the specification
documents from Erdas (err, Leica).
  http://home.gdal.org/projects/imagine/iau_docu1.pdf
You can also dump .aux files with the "hfatest" utility
that can be built in gdal/frmts/hfa.   You would use it like:
hfatest -dt  ungeo_bmp.aux
  DependentFile(Eimg_DependentFile) @ 210 + 22 @ 338
  + dependent =
  +     string = `ungeo_bmp.bmp'
  Band_1(Eimg_Layer) @ 360 + 20 @ 488
  + width = 1119
  + height = 1122
  + layerType = athematic
  + pixelType = u8
  + blockWidth = 1119
  + blockHeight = 1
    Projection(Eprj_ProParameters) @ 2013 + 223 @ 2141
    + proType = EPRJ_INTERNAL
    + proNumber = 2
    + proExeName = (no values)
Best regards,
