[Gdal-dev] Building multipolygons from single polygons with OGR?
Tue Dec 13 22:52:49 EST 2005
On 12/13/05, Ethan Alpert <ealpert at digitalglobe.com> wrote:
> I have a query that returns single polygon geometries and I'd like to loop
> through the features and create a single multipolygon from the result set.
> How is this done with the OGR API?
Ethan,
You could need to create a multipolygon object, and then
call addGeometry() for each polygon.  You can pass in
the original polygons, as the method will clone them internally.
Best regards,
