[Gdal-dev] ERDAS IMG .aux file
Reinaldo Escada Chohfi rec at geodesign.com.br
Wed Dec 14 15:37:11 EST 2005
Thanks Frank. I'll look into the gdal build problem later on.
Reinaldo
At 06:13 PM 12/14/2005, Frank Warmerdam wrote:
>On 12/14/05, Reinaldo Escada Chohfi <rec at geodesign.com.br> wrote:
> >  Frank,
> >  The MSVCRT.lib file exists. In the mean time, I would appreciate if you
> > could build hfatest.exe.
>Reinaldo,
>You can grab:
>   http://home.gdal.org/~warmerda/hfatest.zip
>The -dt switch means dump a tree view of the file in
>question.  The -dd switch will dump a  "data dictionary"
>of types defined in the file dictionary.
> > However, I would like to be able to build gdal due
> > to the fact that am using the gdal utilities more  often and foresee
> working
> > with gdal in programming in the near future.
>Sorry ... I'm not sure why things aren't working.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051214/456b350c/attachment.html
