[Gdal-dev] same code, different result?
gislif gislf at 126.com
Thu Dec 15 02:01:29 EST 2005
Hello,
             Why the same code has diferent result? I have the following code in two deferent seperate program  to generate dataset, one program (which has only these  codes )is ok ,the other(which has other program writen by    qt  )  failed.   why?  seting mistake?
int main( int argc, char **argv )
 GDALDataset  *poDataset;
 GDALRasterBand  *poBand;
 GDALAllRegister();
 poDataset = (GDALDataset *) GDALOpen( "c:\output.jpg", GA_ReadOnly );
 // one program (which has only these  codes )is ok ,
//the other(which has other program writen by    qt  )  failed.
if( poDataset == NULL )
  cout<<"fail to  read file!"<<endl;
  return 1;
gislif
2005-12-15
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051215/fccb6070/attachment.html
