[Gdal-dev] Proj4j >> Projection WKT
Sat Dec 17 15:20:13 EST 2005
On 12/16/05, Sankaran, Deepak <dsankaran at sanz.com> wrote:
> I would just like to confirm whether "Equidistant_Cylindrical" projection
> needs to be translated to "Equirectangular" in the WKT before GDAL-Proj4j is
> able to process it?
Deepak,
My catalog of projections treats these as equivelent,
but lists Equirectangular as the proper name for WKT.
  http://geotiff.maptools.org/proj_list/equirectangular.html
But looking in the morphFromESRI/morphToESRI code
i see that ESRI uses the name Equidistant_Cylindrical.
If you now the WKT is ESRI compatible, you can
import it into an OGRSpatialReference and then call
morphFromESRI() to normalize it.
Best regards,
