[Gdal-dev] PostGIS primary key in CreateLayer
Sun Dec 18 11:57:41 EST 2005
On 12/15/05, Craig Miller <craig.miller at spatialminds.com> wrote:
> I'm not sure if the primary key definition was ever added in CVS for the
> PostGIS drivers CreateLayer method.  If not, here is the snippet to add it.
>     if( !bHavePostGIS )
>         sprintf( szCommand,
>                  "CREATE TABLE \"%s\" ( "
>                  "   OGC_FID SERIAL, "
>                  "   WKB_GEOMETRY %s, "
>                  "   CONSTRAINT \"%s_pk\" PRIMARY KEY (OGC_FID) )",
>                  pszLayerName, pszGeomType, pszLayerName );
>     else
>         sprintf( szCommand,
>                  "CREATE TABLE \"%s\" ( OGC_FID SERIAL, CONSTRAINT \"%s_pk\"
>                  pszLayerName, pszLayerName );
Craig,
I have applied your patch.
Thanks!
