[Gdal-dev] Postgis DeleteLayer(int iLayer) method
Sun Dec 18 12:09:33 EST 2005
On 12/12/05, Craig Miller <craig.miller at spatialminds.com> wrote:
> The existing PostGIS driver didn't have support for deleting a layer via the
> datasource (OGRDatasource::DeleteLayer(int iLayer).  It did have a method
> for deleting a layer via a name, but this isn't exposed via the C++ API.  I
> quickly adapted that function to the DeleteLayer(int iLayer) method, so
> there would be an implementation in the driver available.  I've done very
> little testing of the method, and I didn't make very good use of the
> OGRErr/CPLError mechanism.  I only implemented enough error handling to get
> it to work.
> Here is the code (Just add it to ogrpgdatasource.cpp and delcare the method
> in ogr_pg.h):
Craig,
I have submitted this as a bug report for now.  I would like
to do some testing before I commit it, but I dont' want to
lose it completely in the meantime.
  http://bugzilla.remotesensing.org/show_bug.cgi?id=1020
Best regards,
