[Gdal-dev] gdal cvs 2005.12.19 fails to build
Maciek Sieczka werchowyna at epf.pl
Mon Dec 19 06:37:05 EST 2005
Building latest GDAL cvs to try fixes for Erdas *.gis driver I get
following errors:
ogrpgdatasource.cpp:706:18: missing terminating " character
ogrpgdatasource.cpp: In member function `virtual OGRLayer*
   OGRPGDataSource::CreateLayer(const char*, OGRSpatialReference*,
   OGRwkbGeometryType, char**)':
ogrpgdatasource.cpp:707: error: parse error before `KEY'
ogrpgdatasource.cpp:707:24: missing terminating " character
make[3]: *** [../o/ogrpgdatasource.o] Error 1
make[3]: Leaving directory
`/home/maciek/src/straight/gdal/ogr/ogrsf_frmts/pg'
make[2]: *** [pg-target] Error 2
make[2]: Leaving directory
`/home/maciek/src/straight/gdal/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/home/maciek/src/straight/gdal/ogr'
make: *** [ogr-target] Error 2
Full make.log attached.
GDAL was configured as follows:
./configure --with-hdf4=/usr/local/lib --with-libz=internal
--with-png=internal --with-libtiff=internal --with-geotiff=internal
--with-jpeg=internal --with-gif=internal --with-geos=yes
--with-pg=/usr/bin/pg_config --with-sqlite=/usr/local/lib
--with-xerces=yes
<snip>
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /usr/local
  C compiler:                gcc -O2
  C++ compiler:              g++ -O2
  LIBTOOL support:           yes
  LIBZ support:              internal
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  NETCDF support:            no
  LIBPNG support:            internal
  LIBTIFF support:           internal
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              yes
  HDF5 support:              no
  KAKADU support:            no
  JASPER support:            no
  ECW support:               no
  MrSID support:             no
  POSTGRESQL support:        yes
  MySQL support:             no
  XERCES support:            yes
  ODBC support:              no
  OCI support:               no
  SDE support:               no
  DODS support:              no
  SQLite support:            yes
  DWGdirect support          no
  PANORAMA GIS support:      no
  GEOS support:              yes
  Statically link PROJ.4:    no
  Traditional Python:        yes
  NG SWIG Bindings:
  enable OGR building:       yes
Cheers,
Maciek
Masz k³opot ze znalezieniem czego¶ na mapie? My te¿!
Dlatego stawiamy na nawigacjê! To nowoczesny, najszybszy i najskuteczniejszy sposób!
Zajrzyj i przekonaj siê sam ...  http://www.gps.paragraf.pl/
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051219/017c4556/make.log.bin
