[Gdal-dev] pcraster fix, was: gdal-1.3.1 on FreeBSD 4 fails to build
Cees Wesseling cees at pcraster.nl
Tue Dec 20 14:54:46 EST 2005
Hi all,
I have dumbed down pcrasterutil.cpp so it should compile now for gcc
2.95. It is checked in gdal CVS.
If anyone is experiencing problems with our driver please tell and we
will repair ASAP at our best.
Sam Lawrance wrote:
> On 20/12/2005, at 9:03 PM, paul at warriner.us wrote:
>> Hope this helps someone, as I have little FreeBSD, C, or C++  background.
>> It was run on hub.org using FreeBSD 4.11.
>> I used:
>> ./configure --without-pcraster --with-local=/usr/local
>> gmake
>> http://www.warriner.us/gdal-1.3.1-without-pcraster.log
> The build log was very useful!  When I set --without-pcraster, I
> accidentally left USE_GCC=3.4+.  I've since removed it and GDAL now
> compiles.
Cees Wesseling
PCRaster Environmental Software
van Swindenstraat 97
3514 XP Utrecht
The Netherlands
Tel. 0031-(0)30-238012-4 (-5 Fax)
