[Gdal-dev] Burning text into GeoTiffs?
Ed McNierney ed at topozone.com
Wed Dec 21 12:44:41 EST 2005
Ethan -
Depending on how complex you need things to be, that would work fine -
you could also use MapServer to do all kinds of "annotations" and then
create GeoTIFF output.  You could do that through the mapserv CGI or
using shp2img.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ethan Alpert
Sent: Wednesday, December 21, 2005 12:21 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Burning text into GeoTiffs?
Anyone have any suggestions for writing text into GeoTiffs?
I'm considering using imagemagik to create a image with just the text
and transparent everywhere else then gdal_translate translate to add
gcps and gdalwarp to overlay the text on the output GeoTiff.
Are there any other approaches?
-e
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
