[Gdal-dev] extracing inwatera from vmap0
Paul Surgeon surgpub at telkomsa.net
Thu Dec 22 13:44:42 EST 2005
On Wednesday 21 December 2005 23:18, Paul Surgeon wrote:
> On Monday 19 December 2005 22:56, Frank Warmerdam wrote:
> > As you can see, I had to create soft links so that stuff
> > like "lht." would appear as "lht".
> > Best regards,
> I symlinked all the *. files in the eurnasia dataset but I still get 0
> feature counts.
> orginfo lists all the feature types though.
> Any ideas?
> Thanks
> Paul
Nevermind, I got it to work.
It appears that ogr2ogr tries to use some upper case names (*/hydro/L/L/FAC)
and then it tries lowercase but in the process changes the entire path to
lower case and then goes through a whole list of combinations and fails.
I removed some upper case letters from the path and it worked but I think it's
rather silly that it didn't try */hydro/L/L/FAC and then */hydro/l/l/fac
before messing around with the rest of the path outside of the vmap0 data
directory.
Regards
Paul
