[Gdal-dev] Building with Visual C++ 2005 Express
Simon Perkins sy at perkins.net
Fri Dec 30 19:14:18 EST 2005
For the benefit of other Visual C++ 2005 Express people, here's a
summary of what I needed to do:
1) Download and install VC++ 2005 Express.
2) Download the Platform SDK, as described at:
http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/
3) Set up paths in the IDE as described there. But also add the
following two include paths:
C:\Program Files\Microsoft Platform SDK\Include\atl
C:\Program Files\Microsoft Platform SDK\Include\mfc
4) Since we build GDAL from the command line using nmake, I found I had
to independently set up my LIB, INCLUDE and PATH environment variables
to include the Visual C++ library, include and executable paths. The
command shell that comes with VC++ does not unfortunately set these from
the IDE options, so doesn't include the extra paths you add in the
IDE... But that shell provides a good start - open it up and then copy
the relevant bits of the above three variables to your system
environment variables. Then add on the Platform SDK paths as above.
5) Modify the platform SDK atlbase.h file as described at:
http://groups.yahoo.com/group/wtl/message/12850
You don't actually need to install WTL for GDAL.
6) Everything should now compile using "nmake /f makefile.vc". If you do
a nmake install or devinstall, then make sure the manifest files get
copied along with the DLLs and EXEs. This should happen automatically
with the latest CVS code.
Next task, to check out those C# bindings so I never have to program in
C++ again... :)
Cheers,
Sy
Simon Perkins wrote:
> OK, got it all to work...
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051230/59f0d3ed/attachment.html
