[Gdal-dev] thinplatespline compile problem
Gillian Walter gillian.walter at atlantis-scientific.com
Tue Feb 1 16:49:18 EST 2005
Frank Warmerdam wrote:
>The logic to define HAVE_FLOAT_H or HAVE_VALUES_H was added
>to the GDAL configure somewhat recently.  Note that a cvs update without
>re-running configure will miss this.  Any change that is what you did?
Yes.
>If despite all these there is still a case where FLT_MIN and FLT_MAX
>are not defined feel free to commit such a change.   Just verify the problem
>isn't that you didn't rerun configure.
>Best regards,
I've rerun configure and it works.  Sorry for the bother.
Gillian
