[Gdal-dev] man pages mixed
Silke Reimer Silke.Reimer at intevation.de
Wed Feb 2 07:00:01 EST 2005
On Wed, Feb 02, 2005 at 12:23:20PM +0100, Maciek Sieczka wrote:
> Hi Frank
> On my gdal-cvs-20050115 built from source the man pages for gdal_contour
> and gdaltindex are mixed into one - /usr/local/man/man1/gdaltindex.1.bz2.
> Is it GDAL's fault?
It it the fault of a wront doxygen configuration for the creation of
manpages.
Frank, could you please apply the following patch to the gdal-cvs?
It should fix the problem (and additionally fix the case that no
pct2rgb.py-manpage is created).
Many thanks,
	Silke
--- gdal-1.2.5.orig/gcore/gdal_utilities.dox
+++ gdal-1.2.5/gcore/gdal_utilities.dox
@@ -578,7 +578,8 @@
 \if man
 \section wauthor AUTHOR
 Frank Warmerdam <warmerdam at pobox.com>
+/*! \page gdal_contour
 builds vector contour lines from a raster elevation model
 \section isynopsis SYNOPSIS
 \endif
@@ -702,6 +703,8 @@
 \if man
 \section iauthor AUTHOR
+/*! \page pct2rgb.py
 converts an image into a pseudo-colored image
 \section rsynopsis SYNOPSIS
Intevation GmbH
Georgstrasse 4                    49074 Osnabrück, Germany
http://intevation.de              http://intevation.de/~silke
FreeGIS.org                       http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050202/ac4fa812/attachment.bin
