[Gdal-dev] Error with GDAL+GRASS 6.0.0beta1 support
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Wed Feb 2 07:22:10 EST 2005
Hi
I want to build GDAL with GRASS support.
Gdal 1.2.5 with old GRASS 5.7 cvs was built without error.
Now with GRASS 6.0.0beta 1 GDAL 1.2.5 has this error:
ld: ./port/.libs/cplgetsymbol.o illegal reference to symbol: _dlerror
defined in indirectly referenced dynamic library
/usr/local/lib/libdl.1.dylib
/usr/bin/libtool: internal link edit command failed
make[1]: *** [libgdal.la] Error 1
make: *** [check-lib] Error 2
Without GRASS support GDAL 1.2.5 is built.
The problem now is for GDAL+GRASS 6 support.
Platform: Mac OS X - 10.2.8
Bye
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050202/764baa25/attachment.html
