[Gdal-dev] L1G Landsat data
Frank Warmerdam fwarmerdam at gmail.com
Wed Feb 2 10:27:50 EST 2005
On Wed, 2 Feb 2005 15:49:31 +0100, Stephan Holl <sholl at gmx.net> wrote:
> Thanks for answering.
> Sure, you can download the data here:
> ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p141/\
> r055/L71141055_05520010314.ETM-USGS.LPGS/
> (should be in one line)
> Thanks for looking into this.
Stephan,
Looking in the _HDF.L1G file there does not seem to be any
georeferencing available.  I assume that is the file you are selecting
to get the data?
But the _MTL.L1G file does have various supporting metadata,
including the product corners here:
    PRODUCT_UL_CORNER_LAT = 8.1775571
    PRODUCT_UL_CORNER_LON = 79.5875317
    PRODUCT_UR_CORNER_LAT = 8.1793694
    PRODUCT_UR_CORNER_LON = 81.7280759
    PRODUCT_LL_CORNER_LAT = 6.2812164
    PRODUCT_LL_CORNER_LON = 79.5934122
    PRODUCT_LR_CORNER_LAT = 6.2826047
    PRODUCT_LR_CORNER_LON = 81.7250438
    PRODUCT_UL_CORNER_MAPX = 344400.000
    PRODUCT_UL_CORNER_MAPY = 904200.000
    PRODUCT_UR_CORNER_MAPX = 580200.000
    PRODUCT_UR_CORNER_MAPY = 904200.000
    PRODUCT_LL_CORNER_MAPX = 344400.000
    PRODUCT_LL_CORNER_MAPY = 694500.000
    PRODUCT_LR_CORNER_MAPX = 580200.000
    PRODUCT_LR_CORNER_MAPY = 694500.000
  GROUP = PROJECTION_PARAMETERS
    REFERENCE_DATUM = "WGS84"
    REFERENCE_ELLIPSOID = "WGS84"
    GRID_CELL_SIZE_PAN = 15.000000
    GRID_CELL_SIZE_THM = 60.000000
    GRID_CELL_SIZE_REF = 30.000000
    ORIENTATION = "NUP"
    RESAMPLING_OPTION = "CC"
    MAP_PROJECTION = "UTM"
  END_GROUP = PROJECTION_PARAMETERS
  GROUP = UTM_PARAMETERS
    ZONE_NUMBER = 44
  END_GROUP = UTM_PARAMETERS
So if you use the current development version of GDAL you could assign
a coordinate system and bounds something like this:
gdal_translate 'HDF4_SDS:UNKNOWN:"L71141055_05520010314_HDF.L1G":0'
b10.tif -a_srs '+proj=utm +datum=WGS84 +zone=44' -a_ullr 344400 904200
580200 694500
With older versions you would need to associate the bounds bounds after
the fact with a tiff world file, since the -a_ullr flag is very new.
If you need to handle quite a few datasets, you could write a script
to harvest required metadata from the _MTL file.  I'm sorry there is no
full solution already implemented.
Best regards,
