[Gdal-dev] read prj & metadata from .html file?
Ed McNierney ed at topozone.com
Wed Feb 2 12:08:50 EST 2005
Matt -
First, your reply went to me because I replied only to you.  My
questions were about the sources of your DRGs for my own curiosity, as I
thought I knew most of the places people got them and what they looked
like - I didn't copy the list because it wasn't relevant to your
question.
Find your EPSG file - that is, the file named "EPSG", in your PROJ
distribution/installation, possibly in \proj\nad\epsg.  It's a text file
- open it in an editor like WordPad (it probably has Unix-style line
ends).
Locate the string "<26703>" (no quotes) - it's probably there, but if
you can't find it, search for "<26704>", "<26705>", etc. until you find
one.  These are the NAD27 UTM North projection codes.  The last two
digits are the UTM Zone number.
When you find the closest match, copy the definition line and paste a
new copy, changing the code to "26702", and changing the string
"+zone=3" (or whatever) to "+zone=2".
Save the file and you're done.  The changes will be obvious once you
locate the file and a NAD27 UTM zone definition.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Matt Wilkie
Sent: Wednesday, February 02, 2005 11:39 AM
To: gdal-dev at xserve.flids.com
Subject: Re: [Gdal-dev] read prj & metadata from .html file?
Hi Ed,
> From the GDAL output you sent me separately,
Oops, that was supposed to be general to the list. Is there a particular
reason the default ReplyTo is the individual not the list?
> Updating your EPSG projection definitions to include the values
> reported by the GeoTIFFs you're using is probably the quickest,
> simplest, and most reliable route to a solution.
Oh, I would definately prefer that to my hack-attack. :) I'm glad I
decided to post the gdalinfo output. I almost just let it slide.
How do I update the EPSG projection defintions? I'm using FWTools 0.9.5
on WindowsXP.
thanks,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
