[Gdal-dev] what does gdal-grass provide?
Steve Halasz debian at adkgis.org
Thu Feb 3 12:56:03 EST 2005
On Thu, 2005-02-03 at 10:43 -0700, Jack Varga wrote:
> Markus,
> Thanks, it does help.  Question, does this mean QGIS can't be run
> outside of Grass shell and still load Grass vector and/or raster data,
> even if I compiled QGIS with the grass plugin?  I seem to be able to
> load Grass raster data this way, just not vector data.
If you get the latest qgis from cvs, you can run it outside the grass
shell. I made some commits last night that should help with this.
Steve
> Markus Neteler wrote:
> >>error_routine (fatal = 1): GISRC - variable not set
> > This indicates that you didn't use the plugin and probably didn't
> > run QGIS within GRASS.
> > Hope this helps
> >  Markus
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
