[Gdal-dev] what does gdal-grass provide?
Jack Varga jvarga at boulder.net
Thu Feb 3 12:59:24 EST 2005
Would simply adding GRASS lib dir to /etc/ld.conf.so and running
ldconfig work also?  That seems cleaner/easier than linking all the libs
to /usr/local/lib and running ldconfig.
Markus Neteler wrote:
> Tricky workaround: Link the GRASS libs into /usr/local/lib/
> then run ldconfig (both as root).
